PTmowerMech
- Apr 16, 2018
- 396
- 3,016
Cleaned out the old carb, and it started and ran fine after installation. A week later, customer comes to pick it up and it started running like crap. So I got a new one from Stens. Like the other, it started and ran fine for about 20 minutes. Decided to do some trimming with it, it died at full throttle. I couldn't tell if it sounded like it flooded or ran out of fuel.
Anywho, not it'll only start on fuel poured directly into the carb. Primer fills up fine. The carb holds 7lbs for at least 2 minutes. Compression is over 120lbs.
What plugs up in these cube carbs, that don't allow them to get fuel besides the screen and needle?
After pulling many MANY times, plug is just barely wet. I mean just barely.
