Solid front tires, marathon tires
michaelneff22
I'm to the point I am tired of my front tires getting bumped off the rim/ going flat or whatever the case might be. I need some help with what to purchase. Should I purchase the 5/8" center hole or the 1/2" center hole. Below is a link to what I am looking at.
Current rims are 5/8" center hole, with a 5/8" collar, with a 1/2" Bolt.
I'm wondering do I just leave out the collar and buy the 1/2" hole, use the provided spacers so it can fit in the caster and run the 1/2" bolt through.
If it were me I would stick with the 5/8” and use the collar. Why change what the OEM felt was best for their equipment.
Mower King
Just find you a mower shop that will mount Flat-Free tires on your wheels.....we do it all the time!
