Repairs Snapper SX825-Won't start
jimcahoe
Started last fall. Replaced axle boots recently. Get clicking noise under the seat when trying to start with battery. Also have pull start but no luck there either. I have charged battery.
mechanic mark
Post model number for Snapper SX825.
Support
A number or letter is missing in model number. You can go to Snapper website to download wiring diagram, etc. Check all electrical connections for corrosion,rust, and being tight, especially all ground connections.
If corrosion or rust is present, use a wire brush and be sure to use safety glasses and gloves. Bacon soda mixed with water will help get rid of corrosion.
mechanic mark
Jim, Your model number for your tractor is 7 numbers. If you don't mind, could you please post all numbers from tractor and engine?
