Hi, I recently had a Snapper handed down to me. Engine runs great, blade engages. When I go to put it in any gear nothing happens. I managed to look under the mower while it was in gear to see if all the parts are working and what isn't. The drive disk, friction disk, and axle all appear to be spinning like they should. I thought there may be something wrong in the differential. After a novice inspection no gears/chains appear worn/damaged. Any advice would be helpful.
