I have a Snapper RER 33114520BVE with 14.5 hp Briggs and Stratton engine and I’m having trouble with ignition switch —mower won’t turn off with ignition switch in off position so I have to throttle it down to shut it down
I got a new switch but starting working on it when it wasn’t summer so it was alot cooler out and basically gave up!
Now its hot summer in Florida
All the other safety switches were working
Now I went start the mower to do the lawn and it would not start I wasn’t getting a spark
So I replaced the spark plug and it started right up
Then I realized I was not on the seat and didn’t have the brake/clutch pushed in so apparently the brake/clutch and seat safety switches were not working
I get my best bet would be put in the new switch- trace the wire through the tube with a new wire and make all the connections
The wire that goes to the ignition switch obviously has the insulation rubbed off causing a short
Then I hope for the best
once the ignition switch is changed
Any suggestions or short cuts would be helpful Thanks Mike
