I have a 2013 Snapper rear engine rider. Yesterday when I had the front end jacked up to adjust the wheel alignment I noticed that you could "wobble" the front wheels with your hands. You can move them in an out on the axle and wobble them left and right. I popped off the black plastic cap to adjust the castle nut and found an "E" spring clip instead of a nut. There are gaps between outer washer and the wheels allowing them to move in and out. There also is some "slop" in the bearing allowing the wheel to wobble.
Anyone else have this issue or know of a fix? The mower is still under warranty but I have to take it about 30 miles to the dealer.
Rick
Rick
