Snapper Pro Zero Turn Mower
hogan36
Good Afternoon Everyone,
When replacing/changing the negative and positive Battery Gauge Cables on your zero turn mower, does it make a difference what Gauge you go back with?
They should be 6 ga. Now it doesn't hurt to go the next size large. Here I deal 8 ga cable which I always upgrade to 6 ga when replacing them on mowers. Less voltage drop on long runs. Also if making you own cables using a hydraulic crimper is a must otherwise you have poorly made cables.
hogan36
Thank you!
