Snapper NXT 46inch
aarong24
Recently did an engine swap from an spx snapper to nxt since it's engine was shot. Motor swap went fine and mower runs great. Went to engage the blades annnd nothing. Crawled under and seen this green wire. Any idea what it goes to?
Hammermechanicman
Looks like a ground wire. Does the clutch have a 2 wire connector with both wire intact on clutch and mower side of connector?
Can you find where the other end of the wire goes? That will give us a better idea of where you need to attach the broken end.
aarong24
Think I figured it out. I too initially thought it was a ground wire. Thankfully since the two snappers I have are so similar, I went pulled the pto clutch off the other one. The green wire is apart of a connector that is attached to the clutch and runs to a connector inside the mower. I will swap them out this evening and report my findings.
