snapper model wont stsrt model #7801190 6.75 hp
bigkennyk
snapper self propelled wont start
mechanic mark
Object moved
Select category, troubleshooting, type in will not start. I will also suggest you adjust your valves per you operators manual. If you do not have manual, google B&S engine parts, click on engine and enter your model xxxxxx, type xxxx, trim xx from your engine numbers.
