Snapper Lunges,stutters,lurches
heydude348
when releasing the brake/clutch machine lunges/lurches/stutters.Not really sure what the proper term is.Could it be the “drive” disc or rubber drive wheel?Both seem to be in good/acceptable condition.
mechanic mark
Locate your RER Model # from above & post it, thanks, Mark
You need Operators & Parts Manuals for your Snapper 331415KVE RER, see troubleshooting section in Operators Manual, Adjustments are also in Operators Manual.
Let us know if this information is helpful.
