So I was having issues starting my mower after having it sit for a few weeks. The mower got water in the carb and intake. I got it all out and tried starting it, it would start but only with starting fluid. So, I replaced the carb since it seemed like it wasn’t pulling fuel, when I did that I also replaced the crank case filter, vent tube, air filter, oil fill tube, and the seal for the fill tube. I am in the same situation still, the engine will turn over but won’t fire without the help of ether being sprayed in the intake. I am thinking maybe water got in the fuel now or that the fuel was bad? Any other things that would cause it to not get fuel?
