sjackson57
- Feb 27, 2013
- 1
- 3
I have recently acquired a used Snapper 28" riding mower. Model 281011BE with rear mount Brigg's and Stratton 10 HP engine. Although the mower is about a 1991 or 1992 year it is overall in good condition. Previous owner had it in storage for 10 years. I gave it a complete maintenance, rebuilt carb, new battery, blade sharpen, a quart of 00 grease in the two gear boxes, new axle protectors, new front tires and a few other new parts and she runs great. It has only been run on a well maintained lawn, no sand. Overall I think I have acquired a great mower that has many years of life left in it.
I have a question about the cutting height. The mower is cutting a little short. I believe I have the cutting height at the highest setting (6)? I have St. Augustine grass and used the highest setting on my former toro walk behind self propelled. I am wanting the same setting on the Snapper. The height adjustment lever is on six. Will the mower go any higher? Hi would be the next line after 6? Also on my mower I see in the manual where a grease fitting is supposed to be marked 2L on the the blade spindle. I do not find this grease fitting on my mower. I have found grease fittings on both front wheels and on one rear wheel. Are there any other grease fittings that I have missed. If anyone has any other comments to add about my purchase I would appreciate it.
Thanks
Scott Bradenton, FL
Thanks
Scott Bradenton, FL
