Cheap too.Sounds like there is a small tool to remove the valve core?
If it's just a leak, then you just need to patch it or install a tube. What do you think is wrong with the tire?If it ends up being tubeless, I need to buy a new tire, but then it's basically just prying it off the wheel and prying the new one back on and inflating?
