Hi folks,
This is my first post so my apologies if it's in the wrong spot.
I have a Victor V40 4 stroke push mower that was working perfectly. Couple of weeks ago I was mowing away (it started perfectly cold) but eventually needed to empty the catcher. Throttled down to idle, took out the catcher, emptied, came back to a stalled mower. No big right? Um, yeah, big. It would not restart. I'm used to the habits of this mower and this was new. Normally it will start within 2 pulls even cold, hot is even easier. But this time no. After several pulls with half or even full throttle (no choke) it would not fire, so I tried choke one of two pulls then back to half throttle - no joy. But every few pulls I'd get a slow flame backfire (woooof wooof) sound. I thought I'd flooded it - and probably did using the choke when hot. So I left it for 30 minutes and came back to the same situation. So I left it an hour, then came back. Same woof woof, but I left it at 2/3 throttle and just kept going - eventually it started the fire once and woof woof still. After about 50 pulls (including pulling as it coughed - ie: keeping it spinning) it fired into life and actually ran normally. I finished the lawn then shut it off and immediately tried to restart it and couldn't. Same woof woof would occur. So at this point I'm thinking fuel, carbi, air filter.
I left it for a day, tried again with air filter removed (just to test if it was blocked), same deal (woof woof - but would not start cold). Okay, so I have a problem. Here's what I did to try to fix it:
1) Drained carbi bowl - tried to start, no joy. Same woof woof slow flame eventually (after say 5 to 8 pulls)
2) Pulled off carbi, cleaned all jets with carbi cleaner and wd40 with tube, cleaned needle valve for bowl, tested float operation - all good (i've done this before a few years ago so knew the process). Put back together without issue, but still same problem - no starting but woof woof backfire.
3) Drained the fuel tank and carbi, put in new stuff, same problem.
4) Checked sparkplug - can see visible spark on slow pull earthed to engine. Gap ok. Cleaned spark plug, reduced gab (a couple of thou). Same problem exists.
5) Swore at it a bit, poured a drink (two), had a think about it.
I'm kinda at a loss. If it was timing, why would it eventually fire up again the day it stalled? I agree it's presenting like timing or possibly
valve gap (or burnt valve) maybe?
If anyone has any ideas I'd appreciate hearing them.
Cheers and thanks.
Cheers and thanks.
