geoff.hackett
- Sep 16, 2022
- 1
- 2
So I was mowing the lawn and reverse was not working at a normal speed it was going much slower than usual. Then I turned around and went to go forward again and the pedals for forward and reverse are now sloppy and won't go forward or backwards at all. I tried looking for a linkage that came loose or off but don't see anything that looks like it wasn't connected or loose. The linkage from the pedals appears to move the lever on the right side of the transmission however it is very loose and has no resistance to it what so ever. Looking for guidance on what the issue might be and where to start with necessary repairs. TIA
