simplicity pto switch replacement
HRVCK29
i need to replace the pto switch on a landlord garden trator, model 3#1692024 serial number 1632, the connector on the pto switch is gone, its just connect by connectors and i dont know where the wires go on the switch, below is a picture of the wires, thanks everyone1thumbnail (3).jpg
Email Simplicity and ask them for a copy of your wiring diagram
Make sure you include the model & serial numbers off the id tag on the mower
When you get it post a copy to the forum & we can help you to connect it properly
Nearly all of the connections are ground wires that end up at the coil kill terminal
If you accidently send 12V down one of those wires , even for the briefest time it will fry the control chip in the coils.
HRVCK29
ok thx
