Simplicity Broadmoor 50" Grass Coming Out Front
bk10s
I need some help with the proper adjustment of the 50" deck on my Broadmoor. Grass comes out the regular exit, but I get a LOT out of the front. What am I doing wrong?IMG_6420.jpg
MParr
The deck is probably lower in the back.
Make sure the deck is not packed with grass clippings.
Adjust the tire pressure to recommended psi.
Adjust deck according to the operators manual.
If you are using Gator type blades, that can also lead to front blowout.
7394
Yep..
bkeller500
Is there a deck baffle missing? Available? Check the Simplicity web site for your model and serial number. I recall seeing a front blow out baffle for some model decks in the past.
bk10s
I adjusted the deck so that it is lower in the front......SOLVED!
