simplicity 3110 wont stop running
Jomi
Hello does anyone know if its always with a simplicity 3110 if you turn your ignition off and pull the key out its still supposed to be running if i want to turn it off i need to set my gas in choke then it stops but i think my ignition is just ****** up because the mower itself is already a hunk of **** thanks
