SHAKING LAWN MOWER
brad674
I ran over something with my honda self-propel mower. Once I did it began shaking uncontrollably. I can't find anything stuck by the blade and I don't know what to do to fix it. Any help would be greatly appreciated. Thanks.
SeniorCitizen
If you were to remove the blade and check that part of the crankshaft that protrudes for run out, you'll probably find the crankshaft is bent. Or if you are very lucky only the blade is bent but I wouldn't lay down much cash on that bet.
jteuban
Oh man that Sucks you have prob bent the crank. Maybe if your lucky its a broken flywheel key. But if it's bent that motor will have to be used for parts.
Mini Motors
I just read the title and decided that you have a bent crank.. The good news is that a replacement crank might not be that expensive. And replacing a Honda crank is waay easier than a Briggs crank.
brad674
You were correct, the blade was bent. I replaced it this morning. Thanks for your help.
brad674
The blade was bent. I replaced it this morning. Thanks for answering, even though you were wrong.
brad674
The blade was bent. I replaced it this morning. Thanks for answering.
SeniorCitizen
You were very lucky, thanks to some blade manufacturer that had the foresight to manufacturer a thin wimpy blade.:laughing:
