I have a 48" Raptor SDX with absolutely the worst tires in the world. Great if you are mowing on a flat area but like slicks on a 5% or greater grade. I run diamond industrial treads on my Super Zs but the Raptor has a 9" rim and I can only find turf tires. One thought is to find a 10" rim with the same bolt pattern. Anyone else had this problem and successfully solved it?
