Sd60 leaves uncut strips of grass between blades after a pass. Any ideas why ?
tom tuttle
  • / Sd60 leaves uncut strips of grass between blades after a pass. Any ideas why ?
Auto Doc's
Wrong blades or upside down. I've been sold wrong blades several times.
tom tuttle
thank you The mower has done this from when it was new . that makes sense that Lowes made a mistake .
Auto Doc's
Hi Tom,
Lowe's has an area dealer send technicians out to uncrate and prepare the machines. The blade issue would be a factory assembly defect or mis assembly. Also, someone could have been careless with a forklift.
A servicing dealer is who would need to diagnose and correct this.
Is this the machine you are referring too?
