Scotts riding mower transmission pulley
Orangegud
I was loading this mower on a trailer and was by myself. the mower started to roll off the trailer so i put it into a forward gear to stop it. i got it home, try to start itand it won't turn over. i think i bent the shaft on the transmission pulley. how do i change this. thanx for any help
I doubt it is the pulley. More than likely you have an electrical problem, wiring or safety switch. Try this procedure to make sure that this is not the case, before tearing into the unit.
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position q(you may need an assistant to sit in the seat to override the safety switch).*
Fifth, check for power at the starter while holding the key in the start position (assistant again).*
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
Orangegud
thanx for responding. it's not elect. when i crank it it stops cuz there's a serious drag at on point which won't allow the engine to turn over. i tried to rotate the motor from the top when it stops. seems like somthings preventing it to fully rotate
Ok, that info changes how to proceed. I wound check valve clearance first. If you post the engine model and serial numbers, I will try to post a service manual.
Orangegud
how do i remove the drive belt?
As said it sounds an OHV valve problem. IT may got so loose it dropped a push rod or worn one in two. But we will need the model number of the mower and the engine info.
tom3
Take out the spark plug and try to crank the engine.
Orangegud
thanx to all that responded to my post. When I get to it, I will report back to let u all no what it was for any future members to be.
Catherine
LawnWorld Support
Staff member
Welcome to the forum!
Hopefully, we can help you get that mower running again.
Orangegud
hello forum, as i promised, i'd get back to you'se all to let u know what my problem was. i have to remove the spark plug to allow the motor to turn over. re-insert the plug and VIOLA! it runs nice and even, no hiccups. now, any help would be appreciated. t-u
(too much compression?)
