thebuildingguy
- Aug 27, 2021
- 2
- 6
I have a scag wildcat (SMWC-61v) with a Kawasaki 26 hp liquid (Fd731v). I’ve owned the mower for 3 years and it has mowed like a hoss until this season. The mower will start and run in good order. I’ll engage pto and will mow for several minutes then lose power and die if pto not disengaged in time.
1st action taken -replaced every moving part on the mower deck(pulleys(5) idler arm bearings(2) spindles(3)belts(2). -thought bearings heating up and seizing because when I remove the mower deck belt from the electric clutch, it will run with the pto engaged all day without any problems. (With no load)
2nd action taken - verified all safety switches working properly, all fuel system verified and working properly. All air system cleaned and verified.
3rd action taken- I found 12.6 volts DC across battery terminals regardless of rpm’s
4th action taken- verified 42 volts AC from stator, replaced 20 amp fuse (2) and fuse holder (2) in line on charging system.
5th action taken- removed and cleaned engine ground connections and replaced voltage regulator.
All action items above resulted in no change .
I thought I might run new conductor from voltage regulator output to positive side battery but I cannot find 13.5-15 volts DC IN ANY CONDUCTOR/connector in the system . Should this voltage be present somewhere besides across battery terminals ?
please help!!!!
please help!!!!
