Scag Tiger Cub won't start after replacing fuel filter
pfisterfarm
  • / Scag Tiger Cub won't start after replacing fuel filter
I've recently replaced the fuel filter on my Tiger Cub, plus the fuel line that goes from the engine to the valve that selects which tank to use. There doesn't seem to be any leaks and the fuel filter is about half full of fuel at the moment. The fuel filter is oriented in the correct direction. I can't seem to start it now. Was there something else I needed to do?
mechanic mark
Check fuel valve for being clogged & also check fuel line you replaced for clean fuel.
