Scag Tiger Cat PTO
walkwr0200
Mowing today and the PTO switch would shut off, I could engage again and would cut maybe 30 seconds more and disengage again. Any ideas what would cause this.
Mower King
I would test the Clutch for resistance with an OHM meter....there is a spec resistance number, it will tell you if the clutch is good or bad!
Luffydog
Some go from 2.4 -2.7 ohms depending on the numbers on the clutch
Honda Tech
Adjust the clutch to 0.015" at all three ports. If that doesn't resolve it, most like a bad PTO switch. The new style PTO switch kit is a major improvement over the old.
