I was mowing and my Scag Tiger Cat 61 inch kohler 27hp engine stopped and would not start. There was no engine turning over or anything. It seemed like no power. I checked the fuses next to the ignition panel and a 20A fuse was blown. I replaced the fuse and the engine started but the PTO would not engage. I test the PTO clutch at the green leads off the clutch and read 1.8 ohms. Does that indicate a bad clutch? Should I test the switch?
