Scag STT61A-27ka FD750 FD Muffler replacement
Hi,
I'm having a difficult time replacing the muffler on a Scag Turf Tiger STT61A-27KA FD 750D Kawasaki engine equipped mower, and need some advice as to how to proceed with this project. This mower has the 27 h.p. Kawasaki engine, model FD 750D.
In the service manual it shows how to replace the muffler with the engine only in the photos. Nothing is shown or described as to how to replace the muffler while the engine is installed on the mower.
The problem for me is that the lower mounting bolts are very difficult (impossible) to access as it is on the mower. There are the exhaust manifold nuts, washers and gaskets which is not a problem at all. Looking at the mower from the rear...I am unable to access the bolts holding the lower mounting bracket of the muffler to the motor chassis.
What I'm looking for is if anyone has experienced replacing the muffler and how did they do it? Loosen the engine from the mounting? Any other good advice you may have for me.
The problem is that the muffler pipes coming from the exhaust manifold into the muffler on both sides have broken at the welds completely around the joints. I need to get the muffler off to repair the joints or replace the muffler. NEED HELP PLEASE!
Deamer1
Hi,
Deamer1
