nanobooboo
- Jun 2, 2021
- 2
- 7
Hi, I have a 2015 Freedom Z 52" deck with the B&S 25hp engine. The hour meter died on it. Check for 12v and power's there, but it doesn't work. It's wired so that the clock comes on with the key.
I ordered a replacement per my manual, p/n 484565 (first picture). The vendor sent me the wrong clock, which only has one wire (it's the second picture). I dug around for quite a while and discovered the part numbers changed (Scag probably changed supplier) but the vendor is maintaining that I'm at fault by ordering the "wrong thing". Good grief. On Amazon, the comments on my meter's part number show the same issue.
Any enlightenment out there? To save the trouble, is this unit usable on my machine? I would like to have it wired the same way, on with the key, so I don't see that happening.
I hate fighting with bozos...
