Todster
- May 27, 2021
- 1
- 1
I've seen a couple of YouTube videos where they snip the red positive feed to the fuel sylinoid. Is bypassing the back firing mechanism to the (18h kohler) unit. First of all, is this an okay thing to do. And if so do I need to remove the screw and take off the negative wire as well. And last, If it's okay to disable the solenoid? Can a feller remove the solenoid all together and replace it with a regular carburetor bowl screw ?
