sbass61
tbass61
I have a Toro pressure washer with a Honda GCV160 motor. seems to be popping through the carburetor and won't start. cleaned tank and carb and replaced plug with same NGK as was installed at the factory. Sounds like a timing issue but I could use some help if anybody can help me.
