Orlando123
- Aug 29, 2022
- 1
- 3
Hope everyone is well ! I have YTA22V46 garden tractor/mower. While mowing grass, the engine started to sputter then died. Would not restart. Got it back to my shop. I was able to start the motor, however, when I releasing the foot clutch/brake the engine dies. With the foot clutch/break pressed the engine will run. The engine also will die (while the foot clutch/break is pressed in) and I engage the blade. I have noticed that the forward/reverse pedal does not have a good return action. I do have a lot of time on the mower. I suspect that a safety switch has failed. The seat pressure switch I believe is working. Any ideas? Thanks !
