22R
- May 16, 2013
- 11
- 42
Ok since I have no manual and can't find one online I have two questions
1. Is it ok to partially engage the drive bail to regulate the speed to keep the mower from bogging in tail grass or does the bail need to be all or nothing ? ( does this hurt the transaxle gears ?)
2. In this pic does this washer with the spring attached(can't see the spring in pic) to above the pulley to the left and by that idler tensioner bracket really just stick out like this ? According to the parts breakdown it is there but I can't tell how it would look in real life ? It is the flat washer to the right of the left wheel just below the two cables
3. Machine is running and cutting great but I think I need to adjust the spring tension on the control arm cause it wants to creep and is hard to pull back somewhat. I have the adjustment on the cable out as far as possible.
