Hi Jim,
Remove the two screws on the carb that hold the primer bulb in place. There is a recess that has a screen in it, is it plugged with debris?
Regards
Jeff
This unit does not have a carb mounted primer. The primer is on a bracket that attaches via a plastic clip to the air filter box.
There are plastic hosed that run from the tank to the primer then to the carb inlet. I have not found a screen when disassembling the carb earlier. I have a weed eater that has the setup that you mentioned This carb is different
When troubleshooting earlier I had reversed the primer hoses by mistake. After correcting the error the primer worked fine for a day or two but now it gets hard with a few pumps and will not stay full making for hard starting.
Anyone know why the primer behaves this way ?
