Hi y'all.
I've got a Ryobi Model RY13016(T430) 4-stroke wheeled string trimmer. The rocker-arm stud for the exhaust valve has stripped on the engine head end
just enough that it will run a little while and then loosen the valve enough that it quits. Ryobi doesn't show replacement parts for inside the engine.
The threads in the head appear good. I've tried putting the stud in with red loctite with no success.
Anyone know who actually manufactured this engine or where I could find a replacement stud?
Maybe try blue loctite?
Some other idea?
I didn't want to try the blue loctite until I heard from y'all as it's somewhat permanent.
Thanks,
mud
Some other idea?
Thanks,
mud
