cruzenmike
- Feb 10, 2017
- 57
- 852
I have a 26cc Ryobi 2-cycle string trimmer that is giving me some problems. The model number is RY28040 and it is a half crank model. The problem that I am having is that all of a sudden it is hard to start and it keeps surging and wanting to stall like it is starving of fuel. Choke is working properly and open all the way after warmed up. Fuel line is full with no air bubbles. Last year I replaced the spark plug, fuel line, primer line, primer bulb and fuel filter. The gas if fresh ethanol free with Echo red max 2-cycle oil mixed at the proper 40:1 ratio. Before I start getting into tearing it apart, I was hoping that one of the experts on here could point me at what to look at first. I certainly do not have an issue with simply replacing the carb since it is so inexpensive, but what I am hoping is that the problem is not more "mechanical" and that there isn't some catastrophic failure impending.
I had considered just replacing the power head since I have all of the Expand-It attachments, but I have not found one that I like and the replacement "full crank" Ryobi power head just doesn't spool up fast enough or rev high enough for my liking.
Alternative is to just replace the whole line with the Honda 4-cycle system, 35cc power head and attachments. But if this unit is still capable of working I would like to keep it a while longer.
Thanks in advance!
Thanks in advance!
