Since the front of the deck is pinned to the front axle, over time the axle pivot wears, the machine frame relaxes, and the front linkage gets worn a bit. The combination of this is what 'dips' the deck. There's not a lot you can do about it other than try and bring the items above back into like-new spec. This is assuming your deck shell is not bent or twisted. The only adjuster on the deck, pictured below, only affects the side to side level. The front-to-rear spec is actually 1/4-3/8" lower in the front. You would place the blade in front-to-rear orientation and measure up from the floor to the tip of the blade. The front blade tip should be 1/4-3/8" lower in the front. If you make it perfectly level, both ends of the blade will be cutting at the same time, thus requiring twice the power. This is why the front tip is supposed to be lower than the rear. Deere mechanic 20+ years. Good luck!
