Runs ok after shooting with starting fluid. Won't start again after that without more starting fluid
  • / Runs ok after shooting with starting fluid. Won't start again after that without more starting fluid
Briggs and Stratton engine. replaced carb, oil, checked plug and gap. Checked mechanical interlock and magneto. Not sure if there is a compression problem or not. Any ideas?
upupandaway
What model # mower\motor do u have?
Petriw
Choke not working?
Cusser
Choke not working?
I also say to check the choke, may be stuck in the open position. Anyway, at least you have a workaround.
