SevereDevil
- May 4, 2017
- 2
- 5
49M977 30HP B&S Engine
Ran fine last year, stopped using around September 2019.
Not running properly. I've replace plugs and cleaned carb.
I can pull off the left plug and doesn't phase it. but if I pull off the right wire it dies.
I pulled off the valve cover and found a push rod came off the top valve(not sure if intake or exhaust)
put it back on and tightened it so its not too tight, or loose enough to fall off. its tight but still loose? like very little play.
I put the plug back in and it runs even worse now.... cant get above 50% throttle bc it bogs down and wants to die while throwing black smoke. it pops a few times also. if i remove the plug to the dead cylinder it has spark and runs smoother but still only on 1 cylinder.
not sure what my next step should be. its $35 to diagnose it at a shop which im going to do tomorrow. is there anything else i can do? any ideas what the issue might be?
