You have to pull the entire mower apart
it is fitted under the dash so the 4 bolts under there have to be removed as well as the rear ones
I lift the dash then tie it up to the steering wheel with bungee cords, you need about 1" to 2" of space to get the rear guard out
Then all of the wiring needs to be uncliped
After that the pedals or pedal heads have to come off because the foot boards are part of the same pressing
The seat can stay but as it is quite heavy & awkward it is easier to remove it
This is quite a long job
