Replacement carb has choke, stock doesn't?
juntjoo
Toro mower 20065 - SN 280105976
It surges, kinda weak. Still gets the job done but not ideal. Thinking of swapping this one in. Don't know why I got it as it's not exact but that's what I do lol. Can I? Should I just prop it open somehow or anyone got a tip to make a custom switch? And how does this mower manage cold starts anyway? Not quite that cold yet here in SWFL but apparently it doesn't it some other way. Please explain. I like to know how these things work so I can better work on em. Thanks
Briggs124T02-0161-B1 is suppose to have a primer type carburetor not a choke carburetor.
PN 799868
Cold starts are manage by using the primer to force air into the fuel bowl which in turn forces fuel out the main nozzle into the carburetor throat. Note these primer air bases are known warping and not priming.
Return the new carburetor and get the correct one.
juntjoo
PN 799868
Omg stupid me. I really don't know how these things work. Gotcha. Okay. Should I just break it off somehow or something?
I don't remember if these choke style carbs are ported for a primer or not. Anyway the choke can be just wired wide open.
Maybe someone that more than a handful know if they are ported or not.
But trying to DIY it isn't advisable.
juntjoo
Oh shoot. Good point. I'll have to check that tomorrow. Good thing I didn't put it on yet. It's probably not but judging by your response I might get lucky
juntjoo
If need be I've rigged something before in a similar situation.
Auto Doc's
Get the correct carburetor for the application. There is no "rigging" the new one to work.
eagle86801
I'd buy a rebuild kit and rebuild to old one if its not in to bad of shape
