replacement battery
JGGMC
my 2018 TC2 battery went out. It is a REMY brand. my question is, are batteries all they same quality if the same CCA?
Simple answer, NO. I’ve found that you get what you pay for. I’m not going to recommend any manufacturer as I’ve found you need to rely on your gut. I’ve have always recommended minimum of 375 CCA if you have a single cylinder engine and minimum 425 CCA if you have a twin cylinder engine.
JGGMC
thanks and I will get a little more CCAs than 350. thanks Jeff inTexas
Be mindful of the external size of battery. My former Toro required a shorter battery because it was under the seat, & bouncing could have been an issue..
