Replace the steering pinion gears with new set on my la115....got everything done...still pops when I turn wheel and dont turn front wheels....is there something in the actual "steering wheel" that can be bad....thanks in advance
You use white Lithium Chassis grease from a spray can and you use it liberally.Good point about blocking the wheels but I disagree about greasing the pinion and sector gears teeth. Just attracts dirt and other foreign materials into the teeth leading to excessive wear and jamming.
