upupandaway
- Jul 3, 2015
- 33
- 590
Doing that inside!!!! Not much safer. Only takes a spark. Air compressor kick on, light switch, etc.A sure cure for cancer stick problem. ANd customer wonder why I have no smoking signs around the shop. I clean with gasoline using an air power engine cleaning wand so vapors are all over the place.
I would agree..Sometimes good to be lucky
That why it is done outside. The compressor I have also has a motor with a governor that is continuously sparking during operation. I also use 2 cycle mix fuel instead straight gasoline which raises the flash point yet I prefer using the Purple Power cleaner. The mix is only used on the extremely tough stuff.Doing that inside!!!! Not much safer. Only takes a spark. Air compressor kick on, light switch, etc.
Yeah, We had a local guy that stealing gas from a vehicle. Because he couldn't the siphon hose to pull fuel so he decide the check the tank with a lighter. The tank was nearly so it went up like a bomb. The vehicle was destroyed and the thief got spend some time in the horsepital and a lifetime dealing with the burn scars. Of course there are some other things he had to deal with too. That was just last year if I remember correctly.i vividly remember my Grandpa checking the fuel level in our Mule one time by holding his cigarette lighter by taking the fuel cap off and holding it.... almost in the tank... to see if there was any fuel in it....
He was one of those people where if someone else did it, it would either kill or badly injure them. But not him.
