Craftsman T 110 (CMXGRAM1130036) (13AN77XS093)
Briggs & Stratton 31R907/0062-G1
The battery drains while off. I tested this by multimeter between the negative terminal and the disconnected wire registering voltage.
The battery is good.
With the engine on, the multimeter registered 50+ Volts coming from what I think must be the alternator wire.
But I cannot find the regulator or rectifier to test it. Nor can I find one for this model anywhere. But there must be something to convert AC to DC.
