Well if anything is good while isolating I get things done. My Kubota B6200D needed a new clutch so it got a new friction disc, pressure plate, throw out bearing. It never ran this good when I bought it. One thing I can't seem to figure out as an electrician is the mechanical tach works as do the glow plugs & starter. Neither run through the regulator. My battery charges but the lights, gauges don't work. They do go through the regulator. Since they don't work would it be a good guess that the regulator is pooped? I have checked the fuses. Another question where is the regulator? Thanks
