So I am creating a new post because the only other I can find is a few years old.
Bought a 2010 recycler and the left rear wheel was grinding. Pulled off the wheel and the wheel gear was shot. Bought a new wheel, put it on and got a couple laps in when I started to hear the grinding. Took the wheel off and it was starting to strip again. I read to put some washers between the main frame and the black mount that holds on the wheel adjustment lever. The wheels are out of alignment as well (trying to upload pic). I ordered up some pinion gears as they seem a bit warn, but anyone else run into this issue and get a fix the way I pointed out?
Thanks
Thanks
