Thanks for the manuals Rivets, I will see if they help. The thing is I have ripped all the old wiring out because of too many safety switches, relays etc. I’ve wired a push button switch to crank the engine and put toggle switches on fuel solenoid and coil ground.
Thanks for your input StarTech.
So what should the maximum DC current out of regulator be? I think 15? How many amps?
It is okay to direct wire to battery positive from the regulator with an in-line Fuse?
