PTmowerMech
- Apr 16, 2018
- 391
- 2,999
Roller upper? LMAO..
Some of you may have seen this already.
I just took a 1/4 allen bit, cut a small grove through the center of it, about 1/4" deep. Then cleaned off the burs with a wire wheel. Then attached it to my 1/4 impact.
Screwed a screw into a flat wood surface, to hook the outside end into.
You gotta hand roll it up enough to get your hand over the spring. Then put the bit into the other end and pull the trigger pretty slowly.
Darn thing rolls up in just seconds.
