Recent Service, now engine is very spluttery
andybtsn
Hi all,
I’m not sure how to explain the sound so I uploaded a video, hopefully this helps.
At the end of last summer the mower was increasingly getting harder to start, so thought it was worth servicing.
I topped up the oil, changed the spark, fitted a brand new carburettor, replaced the gaskets, replaced the filter and swapped out the air intake manifold that had cracked. Cleaned everything, drained the fuel and cleaned the fuel tank.
Any ideas?
The carb surface were it mounts to the fuel tank has warped allowing the diaphragm to get sucked under the end and you are pulling fuel around the edge of the diaphragm causing rich running. At a minimum will need to pull the tank/carb assembly and replace the diaphragm between the two parts, or replace the carb with a new diaphragm
andybtsn
Hi, the carb came with replacement diaphragm which I have put in. Not sure this can be the problem? Shall I take some pics?4BB59821-5F90-43B9-8123-FAA5749326D3.jpeg
Did you install the diaphragm next to the tank and then the gasket and then carb. That sputter is very familiar which is the reason that I suggested the diaphragm
andybtsn
I’m starting to wonder if I just installed one, they both looked very similar. So in theory do the gasket and diaphragm sit on top of each other?
Yes
I always do those carbs upside down
So holding the carb in my left palm I sip 2 screws in on opposite side which I keep in place with little finger & thumb
Then
1) place spring in carb
2) place gasket on carb
3) place diaphragm on gasket
4) place tank over carb making sure the screws engage with their holes
5) Push the firmly together then invert & do up the screws lightly, replace the remainder the tignten as you would do a head in a criss cross mannar
By doing this way the gasket & diaphragm are always properly aligned & the spring never falls out .
andybtsn
Yes
Then
That’s worked. Thanks a lot!!
andybtsn
Thank you for your help :)
andybtsn
A slight thread revival but it’s relevant to why I serviced the mower in the first place.
Again, at the end of the summer the only way I could get it started was when the fuel tank was full. If it was half full I could never start it at all, the same thing occurred today, the usual prime occurred but on half a tank it just wouldn’t start. Topped the fuel up and hey presto it started. Any idea why this would be?
If you are talking about the old carb then apart from the diaphragm being work out so not strong enough to suck the fuel from the bottom you also get cracks in the pick up tube or plain blocked filters .
