Rear tire toe in
Mike E. T.
I have a JD z225. The rear wheel is toed in and the rim rubs the mower frame. One rubber tire has blown. What is the solution?
Are you referring the tire being Camber in at the top? For have never seen a rear end on a ZTR toe in but I have the Camber to be off and it would require shimming the transaxles or replacing the mounting brakets (M165214) as they may be bent. Also check the tie place between the two transaxles as it may be loose.
Mower King
The mounting bolts and or mounting brackets have probably came loose or broken off, letting the wheel motor skew. Solution is to 1st, find out why its a skew!
